- Feb 14, 2010
- 1,152
- 227
Pretty sure they are slower in most cases, but a lot easier in where you've got to add holes to trunking and theres not enough room to get a drill in squarely below, just drill a pilot at a crazy angle rather than try and start a cutter bit at a crazy angle!. They go through some quite thick metal as well, have used one on the back of those blakely transformer units in school science labs, which have a good few mm of metal to them (and weigh as much as a very heavy thing!)Those QMax punches are very good, expensive for the number of sizes required though, I have about 4 I think, not sure that they are any quicker than a hole saw, but, they are much neater as long as the enclosure does not twist and distort.
Pet hate of mine, seen at least one panel where there was the waste from a 20mm cutter bit sitting neatly on a section of breakers (it was a sectional panelboard with several sections of mcbs as well) from where they drilled a hole up the top for a stuffing gland for fire alarm cable, it was those 1970's federal stab-loks as well, plenty of exposed busbars that it could have fallen onto!I witnessed one electrical contractor get one heck of a "row" for drilling through the top of a panel to put the mains in without protecting the control gear inside.The end customer insisted on the machine builder replacing ALL the control gear at the electrical contractors cost, machine was new
Choice they had not!
Cost them 5 figures IIRC.
Main isolator, breakers, contactors, I/O, PLC including rack, and various other bits, all because they guy installing the cable did not follow the accepted and stipulated working practice.
Funnily enough don't remember seeing him on the site after that!!!
I like to use an apprentice holding a plastic tray to catch the bits that come out, still a bit scary drilling into a live board though!
Even collared a site agent once to hold a vaccumm cleaner nozzle in a fire alarm panel that I had to drill and tap new cover fixing bolts into cos someone had swept the others up for me headbang
