MARK MCCANN
- Nov 23, 2020
- 19
- 6
I'm planning to run a twin and earth 6mm cable (for an outside insulated structure) The first part of the circuit is intended to be in T&E internally for ease of run and the second part in armoured, externally. At the point of joining them both up, I had figured on using a large metal junction box in order to correctly gland off/affix the armoured. This would then be joined to twin & earth with suitable sized wago type connectors. In regards inaccessible location: Ideally I wish to site the JB under the floor boards securely fixed to timber batons between the joists, sited very close to where the armoured cable enters the house. Is this possible in a non wago JB ? (I wish to use metal as this will allow afford better gland fixing)
Sorry .. pressed enter in error. So to continue....
I don't believe Wago do a metal JB ? Any advice welcome, particularly as I wish the JB to be sited under the floorboard. I am aware that this is notifiable
