extending mains incoming water
tom1
Distinguished Member
Aug 7, 2009
2,330
bit of advise please.
need to move a stop cock, incoming pipe is blue, so am i right in thinking its 25mm mdpe?
i need to extend this below ground, is it the same as working with JG poly pipe?
can i bury joints underground?
was planning to reduce it straight to 15mm then plastic all the way.
thanks
blue pipe & connectors etc are easily available. joints can be buried
im sure SF sells it, but you may need to go elsewhere for a small length of pipe. and i wouldnt reduce it to 15mm underground
