fire alarm call point
sparkyt
Jan 10, 2009
113
im after some replacements and additional units for a system put in by ADT. The call points are marked ADT CP200 and are a two wire connection with plus and minus connections. led to front face too. can any body suggest a direct replacement i can use and source easily. dont really want to have to go to adt and pay through the roof. thanks in dvance
Are these not just the standard Minerva CP200 MCP's but with an ADT badge on? What system is it on, they use a mixture of normal and custom closed protocol stuff.
yes think thats the case. not sure of the panel but it had a lcd display, 8 zones and wasnt fully addressable. thats about all i know at the min. the reason i need some replacemnets is some of the current call points on the system dont have test key facilitys and they want them so they can test all with the same key, some had recently been replaced with the cp200s. there are ten remaining foe me to replace. can u advise a direct replacement and where i can obtain themm from thanks matey
Dunno, I'll have to look into it a bit more. If it's just a standard 470ohm call point, which I think it is, then it may be cheaper and easier to just swap all call points for any 470ohm call point rather than trying to source a few more CP200's.
