Hi I'm making up a Fireplace (underfloor + tabs) water heating, with additional electric boiler / under sink water heater which will serve as a cistern and as a water heater when the fireplace is off. .. So I put 65m of 1/2'' pipe under the floor. Now i'll pass it through my fireplace via copper pipes. .. The water will come from the mains, go through the fireplace then go through the electric boiler (then connected to the taps) nd back to the fireplace . HELP PLEASE : Can I pass it through a 15 L. undersink, waterstorage heater 3kw, SO THAT IT WILL JUST GO THROUGH IT WHEN THE WATER IS ALREADY HOT FROM THE FIREPLACE and so THAT IT WILL START ND HEAT THE WATER WHEN THE FIRE IS OFF ??? THANK U ALL any comment will be appreciated.
