fitting downlighters
paul b b
May 26, 2009
1,751
stuck between a firm pair of t***
hello chaps,
i fitted my first lot of down lights today, i looped through switch so there was less to faff with in the fitting though, 2 x 1.5 t&e was still a ******, i found the last one easy to do as only 1 x 1.5. how do you chaps do it? do you use an adaptor like helyblocks? or just do what you can with both t&e?
thanks
paul
I tend to use 1.0mm on domestic and aurora or jcc fittings and its not too much of a problem to get them in. When using 1.5mm 501's and hr flex are good if expensive, use them on lv lights as well.
hi
i use the ashley downlight j/b for each fitting, makes job little more espensive but saves time. only ever fit l/v lights not really done many gu10's.
i use click fire guard, they take two 1.5 easy enough
take a look at the BRB factors for insulated cielings. With 1mm you would be struggling on a 6A breaker unless the cable installed next to the plasterboard
unless your using cheap B&Q lights, you should be able to get 2x 1.5 T&E into just about any fitting.
failing that, go with the spider method
double surface box/lid & pushfits is the easiest method
a bit like wago's
They're not. Henley blocks are the 100A terminals meter tails are joined in. Not sure what you're thinking of, never heard of anything else referred to as Henley blocks.
Are you sure he meant Henley blocks as thats not what he put in there and it could be a make thats wago-like.
No idea, not heard of helyblocks.
A picture is worth a thousand words. :)
ahhhhh!!! they are called helyconnector or something, they are push fit like wagos, sorry cant find them on the internet, will get the box so i can spell it corectly, i just call them helyblocks for short.
