davetheglitz
Electrician
I've been asked to quote for a rewire of an old farmhouse with big damp problems - existing metal back boxes rotted out. Rising damp to 5ft. Customer does not want surface mount sockets - and will be replastering with lime plaster (it's a builder thing - my understanding is that it breathes so when drainage is sorted outside it will dry out). The customer is adamant that he will not be fitting dry lining to battens.
Anyone got any experience with this situation?
My plan is as follows:-
What do you reckon?
- All cabling to be fed from top down to sockets
- Fit plastic conduit surface mount boxes - but recess back into the walls. Due to wet /unstable walls I intend to bed them onto plasterboard adhesive.
- All cables channelled in and fed into back boxes via cable glands.
- Cables to be rough plastered in with plasterboard adhesive prior to finish plaster.
What do you reckon?
