- Feb 10, 2009
- 342
- 18
For a new conservatory I need to fix sockets etc to what was the external wall.
This wall is being left as is with exposed brickwork. I'm unsure about sinking accesories into the brickwork because of the damage that may be done and obviously there will be no opportunity to make good. I'm also mindful of the fact that the brickwork will be uneven and as such could lead to gaps between the wall and faceplates.
Easy option would be surface mount and also any gaps would then be between the brick face and the back of the pattress. (Of course this option is not not the best looking)
How have others tackled this is the past and if you went for flush mounted, what kit did you use to chop out the brickwork?
