Hello. I'm new to the forum and going through training.
I have been getting conflicting advice from a couple of qualified electricians and my tutor and would appreciate some advice.
For the installation of a photovoltaic system with a 1200w inverter about 15m from a new consumer unit, I have been advised to run the a/c in 3core Flexi. This would be clipped through the loft, down an internal wall in conduit and then along a garage wall at ceiling level and finally down the garage wall again in conduit. The reason for the advice was the slightly lower voltage drop.
My tutor thinks it should be in twin and earth but I can't find anything in 7671 that says Flexi can't be used so long as it otherwise follows code.
Having said that, even if it is technically OK but is considered unprofessional, I would prefer not to push it on an install that will be used for an *** assessment.
Any comments welcome.
