Steps i just replied but my post has gone missing!!!
I'll type it again just give a moment
Sorry guys for taking so long to reply back!
Just been mega busy at the weekend trying to keep everyone pleased at home and visitors etc!
Well what stumped me was some friends have just moved into their new home and they gave me a call as their electric cooker wasnt working.
Me not intending to do any work this weekend just took minimal of tools and said to the mrs "oh it will just be a quick visit". (Haha I hear you all say)
So i get to friends new house and have a look around, noting that the consumer unit is totally innaccessible due to being right up the back corner of the garage and their is a whole houseful of their contents in their! So as you can imagine Im a bit restricted to what I could do
Anyway back in the kitchen I plug my fluke mft into the socket on the cooker control switch and have 245v L-N and L-E, with 8.9v N-E. So i presumed everything is ok at that point. Then I pull the cooker out and get same voltage L-E but nothing between L-N.
So now Im thinking the problem lies between either faulty cooker switch or maybe a dodgy junction box on load side of switch to the cooker.
After a bit of discussion with my friend he decides instead of moving everything out the garage (i havent got much time to stay as the boss wants to go to blxxdy merry hill shopping) then he is going to climb over all his stuff to the consumer unit with me watching and his mrs shouting at him to be careful and not break anything :slap .
Luckily the breaker for the cooker is marked up and circuit isolated.
On removing cooker switch (thinking Im going to check connections and test continuity of switch and cable to cooker) I found the neutral conductor was loose in the back box - this was the supply cable. So after reconnecting this everything and all of the other connections which my daughter could have done up tighter made everything ok.
Later that day back at home, I purposely disconnected a neutral from a socket and with the 3 lead plug tester it still shows a L-N reading. However it wont let you do a loop test (error 4) for L-N and it comes up >2000 for L-E.
Hope this all makes sense.
