The sparky put a bigger cable in for this exact reason so I'm sure he had a plan of how to do it. My boss won't pay for him so I got to do it. I'm not a sparky by any means and I'm not pretending to be. I have basic knowledge and that's it.
So what I'm asking is it just as simple as a bigger fuse? And if not, why? And does anyone have an idea what the sparky's plan was if it wasn't to do that?
James,
This is a little more complex than first appears.
It is IMHO too complex to explain over an internet forum.
You need to verify the volt drop for the cable for the increased load, and if the cable is as you say 35mm sq. then you will need the full details of the reactive load, r, x & z values to do this.
Once you have this, you will know the volt drop on the sub-main.
Then you can factor in the volt drop on the distribution circuits at the far end of the sub-main, then the final circuits in each caravan etc.
Then you go on to the rest of the design calculations, and it may be an iterative process.
Now the issue that you have is this is a workplace, and EAWR applies in full, thus, there is a statute law requirement for those undertaking the work to be competent and comply with EAWR.
From your posts it does not seem that you meet this statute law requirement, thus, due to your own admission you are not competent to do the work, therefore you would be knowingly breaking the law, criminal law.
As would your employer (company), and your line manager (personally).
This is not something that should be taken on lightly, you could easily end up killing someone if you get it wrong.
Would you really want to do that.
The other guys have tried to advise you against this in their own ways, they are a little more abrupt perhaps, in their manner, however, it does not change the fact, that you have admitted incompetence, and, thus you would be committing a criminal offence under H&S law if you did this work, as would your employer (company) & line manager (person) for putting you in this situation.
It may not be what you want to hear, however, unfortunately it is the truth.
