Well it's not, so yes, I'd be worried too. Either fit it after the existing fused spur or fit the proper kit for the job. Price should be secondary to the primary concern of it being somewhere near being done correctly.A customer has a heater off a fused spur, they want to put a timer on it.FCUs with inbuilt timers are expensive. Can I use an immersion heater timer, I worried it might not be fused?
is the fuse really needed? maybe just get a timer instead.as patch says, keep the job simple and buy the spur/timer.
Presume? How can you presume something and then say definitely?Depends on manufactures instructions, but I presume it will have come with a plug top so I would deffinatley say yes.
doesnt always need it. un-necessary fuses can only cause trouble later.I meant to say If it came with a plug top I would deffinatley fuse it.
That's what you said before. Why definitely fuse it? 3KW load on a 16A radial, no fuse needed but you'd fuse it anyway? You must be one of those people who goes OTT and fuses everything whether BS7671:2008 calls for it or not.depends on manufactures instructions lurch. I meant to say If it came with a plug top I would deffinatley fuse it.
and skip the fuse where there should really be oneThat's what you said before. Why definitely fuse it? 3KW load on a 16A radial, no fuse needed but you'd fuse it anyway? You must be one of those people who goes OTT and fuses everything whether BS7671:2008 calls for it or not.
