davi
- Jan 26, 2010
- 6
- 0
Hi, I'm having a bit of a nightmare. I'm really hoping you can help
We're a small business just moved into an office. We have two laptops connecting to external monitors. Both are the same model laptop (HP DV2530ea) and both monitors are the same (Dell ST2410). The monitor screens flicker like crazy when the laptop is plugged into the mains. When we pull the power lead out they stop flickering.
After reading on the web, we think we have a ground loop problem. We have tried buying shielded monitor cables, HP docking stations, using extension leads but nothing fixes it. The solution offered on other forums is to cut the earth lead in the plug which apparently fixes the problem. But we are quite nervous about this as the earth is there for safety reasons.
Has anyone got any advice please. There must be a solution!
Thanks in advance
Thanks in advance
