ianmacd
- Mar 15, 2009
- 3,877
- 0
Along with the pic on the monitor .If I remove the Power supply to the monitor, the buzzing goes away.
It's not the power, it's the feed to the speakers.Along with the pic on the monitor .
What's it like if you run the monitor on it's own through the UPS?nope, used UPS and still same issue, although UPS is not a particularly great one to be fair
2 pin equals 3 pin without earth - looks like we've got ourselves into a loop as well... O)Toshiba incidentally provide a 2pin AC Adaptor, as well as a 3pin, so I have ordered one to see if this helps.The thinking is that if it is a Toshiba proved part then will be safe to use and I can give them to the customers with the problem.
That doesn;t look cheap, put that down as plan B after changing the power supplies to class 2 devices!Some useful reading here.
