My Halstead combi boiler started losing pressure last week & the engineer 1st thought it was the pressure vessel knacked,but on closer inspection said it was due to topping the pressure up to 1.5bar instead of 1 & he pumped some air into the pressure vessel with a hand pump & left,saying the boiler was now ok.The problem has now returned,with water dripping from the expansion pipe outside the house & loss of pressure from the boiler,which is in the loft of a semi.I would be grateful of any help with this problem.Thanks in advance,
Hz
Hz
