Aren't we more likely talking about some component or other failing after being switched on for a short while? Or what about a break down of insulation somewhere on the circuit, due to heat, damp, rodent damage. All of these could produce your symptoms. I would go back to basic fault finding techniques proving each area until you locate the cause.what is the maximum emergency lights you can on one 6amp breaker the problem is after ten mins of being on it trips the breaker many thanks Ash
