but Mr Evans was asking how to get around fitting an RCD if I'm reading his [ost correctly.or just stick in an RCD... if tit trips its usually because its faulty
Not exactly Binky , I've been putting welding sockets in for years but never with an RCD .but Mr Evans was asking how to get around fitting an RCD if I'm reading his [ost correctly.
Now , with the Regs coming in over the last few years , we started with RCDs for outside sockets ............ then it was virtually ALL sockets unless you fitted a label ....then it was under the control of skilled personal...then it was for ALL circuits in a bathroom ....then for buried cables unless they were a certain depth deep in the wall ....... also sockets up to 20 amp was it ?? but include over 20A for mobile vehicles ....on & on ...now we have 300 different types of RCD in the equation .
It has got silly , where you adapt to one upgrade and then they keep adding and altering .
Domestic work now , I think just RCBO s on everything , end of . All this pratting about . What was it ? Freezer socket without RCD but MUST have label , but you can't do that because the cable is buried in the wall less than 50 mm deep , but you could use a Flexishield cable , but then you'd have to buy a whole drum @ £1000,000 .
I think it’s all got out of hand.
change for change sake ....
more like change so IET get a few back handers from manufacturers for selling more of their products...
