wikkinade
- Jan 19, 2009
- 7
- 0
Hello everyone. I wondered if anyone could give me some advice on how to figure out what's wrong with my Creda economy 7 storage heater (model 79351/ISR18A) because I have no clue when it comes to electricals! My housemate recently moved out, the heater worked in November but now it won't.
I've tried it on several settings between high and low and it won't work at all. I've checked the mains, all the wires are secure. I've looked at similar threads on here and 'fuse links' are mentioned. Please excuse my ignorance but where are these located? Blushing I couldn't see anything when I checked the wires and unscrewed the switch casing. Other than the two dials there doesn't appear to be anything else on the heater I can physically check?
Does anyone have any advice (needs to be put in simple terms) or a fault finding system I can use to fix this or figure out what is wrong? Any help greatly appreciated!
Thank you!
Thank you!
