avinalarf
- Joined
- Jun 2, 2008
- Messages
- 415
- Reaction score
- 0
Testing a ring and get 289ohms for line-earth and 222ohms for neutral-earth.
But when I try testing for line-line or line-neutral my Fluke 1652 won't do anything . Any suggestions? Could I be doing something wrong?
A PME installation and at the main fuse (is this what you guys also refer to as "cut-out"?) there are 3 earth cables coming from it, but only 1 of them at the CU. Does this mean that one goes to water and the other to gas? Would this at all explain why I'm getting 201ohms when I do a continuity test from the CU to the gas?
TBH, I'm not 100% sure how to check the bonding with this sort of set up. Some guidance would be greatly appreciated.
Nat
Nat
