Help with wire location
Can you take a switch off and tell us what colours go to what terminations... Com, L1 & L2
Without that we can only guess
This is the picture i took today when finding switched live. Any good?   (Upstairs Switch)
Cheers
OK....
so assuming that the other switch is wired the same and it is how you've said.....
Connect the two reds from the T&E and the two blues from the 3&E together (this is the permanent live)
Connect the two reds from the 3&E together
Connect the two blues yellows from the 3&E together (this is your switched live)
Connect the two blacks from the T&E together (this is your neutral)
Obviously connect your Earths together
Now your light connects to the switched live, neutral and earth
Good man.  Im finishing work early tomorrow so will do it then. The spark is coming to check it all anyway next week.   My mother doesnt trust me.   No wonder
thanks again.
cheers
OK....
Connect the two blues from the 3&E together (this is your switched live)
Did you mean yellow here Noz?
Guys, a big thanks to everyone who replied.  Im sure i will be back sometime.soon.
cheers
