Each storage heater will be rated in KW. Thats 1 hours use and it equates to what you would theoretically use if it the heater was on and never got to temperature. . e.g. if your storage heater is 2Kw then if on a normal tariff that would be 68p/ hour of it being on. (assuming it was permanently on) so two of them that would be 1.36/hr. ... an energy monitor like this:A tenant has noticed extremely high electric bills since having storage heaters installed.
Would an electrician be able to tell me the cause?
Thanks for your reply .. I’m checking the tarrif. He says he’s using 997Kw per month . It’s that excessive for a small one bedroom flat?
Clearly likes a warm flat. Half the trouble with NSHs is people simply don't understand how they work.Thanks for your reply .. I’m checking the tarrif. He says he’s using 997Kw per month . It’s that excessive for a small one bedroom flat?
You could run a Airsource heatpump for a 2 bed or bigger on that amount of KW. wether it is excessive for that kind of flat is hard to say although i would think almost deffinately. much would depend on:Thanks for your reply .. I’m checking the tarrif. He says he’s using 997Kw per month . It’s that excessive for a small one bedroom flat?
My other thought is are they actually storage heaters could they be one of the many panel heating offerings that claim to be cheap to run
