Just been to job today to add 2 sockets into attick conversion tested socket in bedroom which was to supply spur with 13A fuse the zs was 312 ohms and ze was 320ohms the owner said last electricians said it was a bit high and knocked in earth rod(outside front door earth seems damp enough) a bit more and it was ok which from the readings i have this seems they didn't get reading down the system is protected by a 30ma rcd not time delayed 100ma, do you think i need to fit new earth rod :|
