Apologies for the post but I am getting frustrated and wanted to vent my frustration.
i have a Greenstar 30CDI which is connected to a Hive system, I had an issue with the heating to the po8nt that it would not fire up the boiler. We have a 2 x 2way valve system. I called a heating engineer to take a look. I posted the job on Rated People, the description of the job was as willows:
I have had a new valve fitted so I know it’s not that. The hive system was fitted but has never really worked, we can not have just the heating on but need the hot water to get the heating to work. Please note ITS NOT the diverted valve. The hive controller is the issue, we have tried another one with the same issue. The hot water alone works fine, it’s just the heating that we have an issue with. On the Hive receiver wiring The N is connected, the L is connected, we are missing a common connection and the heating off(NC) is also not connected to anything. the heating on (NO) is connected and the Heating On (NO) is also connected. The hot water works fine, it’s just the heating. please don’t come if you can’t know how to wire a Hive to a Worcester Bosch’s Greenstar 30CDI Classic. I believe this is more of an electrical/wiring issue then everything else, the boiler does NOT need replacing, the diverted valve has already been replaced, 4 weeks ago, it’s the heating control that is not working.
The guy turned up and said he would fix the issue and has never failed to get one fixed, he returned the next day and said that he wiring was a mess, and to be honest it was a little messy, so he suggested it needed correcting, I agreed and he then realised the motor for the hot water valve was faulty. He replaced the motorised valve on the Honeywell 2 vat valve, he turned on the heating and the valve opened and closed, I paid him and he left.
when we checked the system we found that the heating did indeed work, however when we turned the heating off the boiler temperature went to in excess of 120degrees and kept climbing, I switched it off after speaking to Worcester Bosch’s. I turned it back on again and the system started up, without the heating or the hot water on the boiler continued to run all night, it sounded as if the boiler pump was running.
i now have had to keep the boiler off for the past 4 days due to it being dangerous, another weird thing is that we have no power to the hot water and the immersion is turned off, however we have a very hot water talk, it seems to have permanent heat despite the immersion light not being on and the boiler being off for 4 days now.
i have culled the guy back, and you guessed it I’ll be there on Monday, then Tuesday, I then text and called him today and no answer.
i now have no hot water, well from the boiler anyway, no heating, glad it’s summer and a tank that is permantely hot. The fault was just the heating valve, now he has retired it it’s a complete car crash.
thoughts, guidance would be really appreciated.
