Sharpend
"It Just Is"
So we are going back to tying cups on the ends of strings now are we!!
I have all my AV kit in a central cupboard (under the stairs) and from there hdmi cables to feed the two main televisions. With wall hung tv's you don't want set top box clutter where the tv is. I use hdmi splitters so the same box can feed both tv's simultaneously if you want, and IR extenders so you can control all the stuff in the cupboard from both rooms.Data cabling is likely to be more useful, especially from your router to any smart TV /digital recorder location. Consider also HDMI cable from your main (smart) TV to second sets if you may want to use those facilities remotely. Both these are things I've added in my bungalow.
I want to run cables for a multi zone home audio system
one size does not fit all so there are many solutions to the problem, i dont have enuff time to list em all! ;-)!why not just post it here?
Ow doez u change de gramafone record? ;-)I have all my AV kit in a central cupboard (under the stairs) and from there hdmi cables to feed the two main televisions. With wall hung tv's you don't want set top box clutter where the tv is. I use hdmi splitters so the same box can feed both tv's simultaneously if you want, and IR extenders so you can control all the stuff in the cupboard from both rooms.
Both have surround sound systems with all speaker cabling built into the walls during the build.
House audio is from an old hifi unit in the same cupboard, again with IR remote control so you rarely have to actually physically touch it, that feeds speakers in each room, all cabling built in at build time. Main audio source is a raspbery Pi Music box.
I am not a fan of smart tv's. I prefer a couple of good but old dumb tv's and a cheap firestick for all the smart stuff.
you don't. All music is streamed from the Pi Music box, controlled by any computer or phone in the house.Ow doez u change de gramafone record? ;-)
Sounds very much like my son's house. Understairs looks like the network cabinet of a server room.I have all my AV kit in a central cupboard (under the stairs) and from there hdmi cables to feed the two main televisions. With wall hung tv's you don't want set top box clutter where the tv is. I use hdmi splitters so the same box can feed both tv's simultaneously if you want, and IR extenders so you can control all the stuff in the cupboard from both rooms.
