[SIZE=10pt]Hello[/SIZE]
[SIZE=10pt]I was wondering if anyone could please help me:-[/SIZE]
[SIZE=10pt]1. [/SIZE][SIZE=10pt]I have bought a new build (and the developer has disappeared !!). I have recently noticed that the hot water is very very hot (80 + degrees) – but has been ok in the summer. I have called out British Gas who has told me that the problem is likely to be faulty wiring causing the central heating (when turned on) to heat the water in the thermal store to a very high temp as well as heating my radiators as the cylinder stat is wired wrongly ??[/SIZE]
[SIZE=10pt]2. [/SIZE][SIZE=10pt]Could anyone give me views on this assessment ?[/SIZE]
[SIZE=10pt]3. [/SIZE][SIZE=10pt]My system is a MAIN condensing boiler with a Gledhill thermal store.[/SIZE]
[SIZE=10pt]4. [/SIZE][SIZE=10pt]Many thanks in advance.[/SIZE]
