- Feb 5, 2009
- 5,612
- 0
When was this work done? If it was recently and in a kitchen then is it protected by a 30ma rcd?
Thought they made showers :coatOh yes, Definitely a lollypop circuit otherwise known as a radring Reg 514-45 .I've seen loads of them and for the life of me I can't see a problem with it TBH.
How did you get the Gnat to stay still long enough to carry out this experiment in Entomological Abuse?... :coatSO's are rated at 20A due to the thickness of the internal copper, rather than the current carrying capacity of their terminations. However, having recently fitted a 4mm ring main, I would question whether you could fit 2 x 2.5 and 1 x 6mm in a socket outlet without pruning the 6 mm. I couldn't fit a gnat's willy in after 2 x 4mm so 6 + 5 seems a bit steep.Cheers, Chris
He stuck it to the lollipopHow did you get the Gnat to stay still long enough to carry out this experiment in Entomological Abuse?... :coat
That's a point I was going to make. If the cables fit the terminal without pruning, then the screw will be clamping all the cables together, so the 30A will NOT flow through the SO but from adjacent cable to adjacent cable.SO's are rated at 20A due to the thickness of the internal copper, rather than the current carrying capacity of their terminations. However, having recently fitted a 4mm ring main, I would question whether you could fit 2 x 2.5 and 1 x 6mm in a socket outlet without pruning the 6 mm. I couldn't fit a gnat's willy in after 2 x 4mm so 6 + 5 seems a bit steep.Cheers, Chris
