How many forum members does it takes to change a light bulb?
Nov 28, 2009
14,841
1,026
1 to change the light bulb and to post that the light bulb has been changed
14 to share similar experiences of changing light bulbs and how the light bulb could have been changed differently
7 to caution about the dangers of changing light bulbs
1 to move it to the Lighting section
2 to argue then move it to the Electricals section
7 to point out spelling/grammar errors in posts about changing light bulbs
5 to flame the spell checkers
3 to correct spelling/grammar flames
6 to argue over whether it's "lightbulb" or "light bulb" ... another 6 to condemn those 6 as stupid
2 industry professionals to inform the group that the proper term is "lamp"
15 know-it-alls who claim they were in the industry, and that "light bulb" is perfectly correct
19 to post that this forum is not about light bulbs and to please take this discussion to a lightbulb forum
11 to defend the posting to this forum saying that we all use light bulbs and therefore the posts are relevant to this forum
36 to debate which method of changing light bulbs is superior, where to buy the best light bulbs, what brand of light bulbs work best for this technique and what brands are faulty
7 to post URL's where one can see examples of different light bulbs
4 to post that the URL's were posted incorrectly and then post the corrected URL's
3 to post about links they found from the URL's that are relevant to this group which makes light bulbs relevant to this group
13 to link all posts to date, quote them in their entirety including all headers and signatures, and add "Me too"
5 to post to the group that they will no longer post because they cannot handle the light bulb controversy
4 to say "didn't we go through this already a short time ago?"
13 to say "do a Google search on light bulbs before posting questions about light bulbs"
1 forum lurker to respond to the original post 6 months from now and start it all over again.
How many forum members does it takes to change a light bulb? 1 to change the light bulb and to post that the light bulb has been changed
Would you like it moved?
As there are more than 5 sparks what about the following
1 to write the Risk Assessment
1 to write the Method Statement
1 to write the health and safety policy
1 to to carryout requirements of the CDM regs :innocentROTFWL:innocentROTFWL
As there are more than 5 sparks what about the following1 to write the Risk Assessment
and dont forget 1 to hold the torch so the other 11 can see in the dark :slap
i would have done full eic instead, as you should really make sure the zs, r1/r2 of circuit can with stand the fault current, also test the earthing on incomer to make sure the light fitting you have last worked on has a good earth path under faukt conditions, check ZE and KA for incoming mains :slap
5 to discuss whether, rather than simply replacing the blown lamp, you should not instead replace the simple lamp with 2 rows of halogen downlighters consuming 4 times as much power.
7 to discuss whether these should be 12V or 240V downlighters
4 to discuss whether the downlighter upgrade necessitates the addition of an RCD to the circuit.
3 members to suggest a complete rewire from the switch and supply side in approppriate new cable colours, using a new harmonised twin brown for switch drop instead of the original red/black cable
