Hello guys , me again.
I know what your thinking does this guy know anything , well yes but limited , but i want to know more , i want to know it all as my job really interests me , and when i dont know it frustrates me , thats why i get the education from you guys that know .
My local shop ( 3 doors down ) wants a new lighting arrangement , specified 600mm x 600mm led modular fittings .
Shop dimensions are approx 5.5m x 9 m . What i need to know is exactly how to work out how many panels will be needed ?
Each panel has the following technical info , available in 4000k-4500k , 4500k-5000k and 6000-6500k which im guessing is warm white , cool white and daylight.
Each panel produces 3200 lumens at an angle of 110 degrees ( equates to 40w panel ).
The whole shop is to have a new false ceiling fitted , im guessing using 600mm x 600mm panels , but possibly 600mm x 1200mm panels , i know i need to know this before arranging panels Thats why i want to know exactly how to design the lighting for this space so i can adjust according to requirements .
I have created a grid layout and have concluded that 2 rows of 4 panels , spaced 1200mm from outer walls with 1800mm between the 2 panels ( shop width ) and spaced 1200mm from outer wall with 1800mm between the 3 panels , leaving a space of 600mm between last panel and wall , which is where the till is sited ( shop length ).
any help will be gretly appreciated
regards
wayne soppitt
regards
wayne soppitt
