I've a new build to start shortly.
It has an external meter cabinet flush mounted with the outer brickwork.
The tails will be 20m so I will have issues with the relevant DNO as to protection etc. but how would you run the tails from the cabinet to the cu?
I see 3 choices:
1 Straight through inner wall, earthed metal capping to ceiling void then internally to cu. (Would need to identify safe zone for run to ceiling height by socket or other).
2 Run tails from cabinet, 2m up cavity then through inner wall to ceiling void and onto cu. (cavity is filled with glasswool insulation so possibility of deration).
3 Externally from cabinet up outside wall and through to ceiling void. (What to use to protect tails externally and keeping inside of cabinet watertight).
The internal walls will be dot and dab plasterboard
I'll be interested in your ideas.
Dave
I see 3 choices:
Dave
