Hi, this probably sounds a bit crazy, but i was thinking of setting up a practice test board as you find on a electrical course. Comprising of a consumer unit, earthing block, 2 bonding pipes, shower circuit (terminated at a 60 amp connector), cooker circuit (also terminated at a 60amp connector), Ring main (5 sockets), Lighting Circuit (2 lights, 3 switches). Just to practice testing!!
My Question is:
Could i use, say a 13amp plug to energise the circuits (to the main switch)?
there will not be any load on the circuit, just worried about the safety factor!!
I understand that my Ze, pefc and pscc etc will have higher readings, not being from the main supply.
Any suggestions will be much appreciated
My Question is:
