freedomrun
- Feb 3, 2010
- 65
- 0
Anyone give me some advice on IR Testing a domestic (tn-c-s PME) install at a socket outlet. I've been asked to replace a light fitting, so wanted to perform an IR test on the lighting circuit as part of my initial verification. The CU is packed and quite hard to access in the cupboard it's been boxed in to. If i were to leave the Main Switch off and all the MCB's closed (on) and perform my IR test at a socket outlet between L-E and N-E only, surley this will test the whole install and be adequate for a Minor Works if the readings are compliant, i would also take into account any light switches for two way or intermediate. I would prefer to test at a socket outlet as i have'nt got to perform the testing up a ladder. I know i could get some light mates testing adaptors - my question would still be the same even if i used light mates instead of connecting my IR tester to the socket outlet. Also, will this way of IR testing work on all types of boards, what if RCD's are present? Any advice appreciated - Thanks.
