Insulation testing earth fault... strange one
so you get a shock because you havent earthed properly in the first place.we really need to get reading up on the purposes of proper earthing on this forum.
err.. Mr earth everything my way and ignore everyone else....
were not talking about earthing. if you didnt have the polarity wrong, then turning off with SP MCB would isolate and leave installation dead. leaving with wrong polarity means when you isolate via SP MCB, installation is still live. i dont really care if you want to add an RCD or not, the fact still remins that it has been left in a dangerous state, and the earthing has nothing to do with this.
It could possibly be the RCD/RCBO. Some of the modern devices are electronic and give low readings. Presumably when you do a global reading you will be testing through at least one of these devices
I though isolation had to be via a DP device.
I always thought that but IIRC I looked into it to find something to back up my argument and only found stuff to the contrary so I kept quiet. ;)
