retiredsparky
- Apr 15, 2009
- 36
- 0
What happens to the conformity certificate?
i know a wylex RCBO will fit with a bit 6mm between existing busbar & new RCBO. MK also do a conversion kit for their RCBO & MCB's to fit into itGreat thread lads and a subject that has me scratching my head on many occasions and I'm scratching again. :C I've an old mk sentry board with a MK LN 5945 MCB 45 Amp BS3871 M6 Type 2 and was wondering if there are any RCBO's that I could replace it with?
Failing that is there a straight swap for the main switch for a main RCD per chance.
Reason I'm asking is that I've to change a shower like for like in rented accommodation and the landlord doesn't want to go to the expense of changing the whole consumer unit even though I've mentioned the regs to him regarding the protection required for the shower and power points etc.
Board in question >>>>>>>
should be able to get a wylex or just about any other in thereWhat fits into a Proteus board other than Geyer please guys.
just what I needed to know for todays little job,Wylex NSB rcbos fit Tenby/Legrand 16th splitload boards.
Salt and vinkier nice.just done another.........i fit proteus rcbos in a vinkier db. They went straight in.
Manufacturers of distribution boards do not recommend that you install other manufacturers breakers. If anything goes wrong you may have a problem on your hands.
When out in the real world with an old CU and inability to locate an exact manufactures now obsolete part the next best option has to be considered. As with all business decisions the customers requirements, budget, safety risk assessment and feasibility to complete the job within a reasonable timescale, carry a large sway over decision making. If manufactures original parts are available I doubt any competent electrician would choose to fit other manufactures parts. However we sometimes have to make a considered judgment over what is best for the customer. Remembering of course a small load domestic circuit probably posses less risk than a heavily loaded commercial circuit. I would be interested to hear off any of our members who have first hand experience of failures in a CU directly due to mixed manufactures parts. Most car manufactures recommend only their original parts are used during servicing and repair work.Picked up a copy of professional electrician today for October 2011. Page 41 " mix ' n ' match" article states that installing different mcbs or rcbos from different manufacturers you could be liable if something goes wrong. I've done this before to get me out of trouble but I don't think I'll do it again.
