mouse,
if I can be as pertinent to ask, at what stage of your career are you.?
you can PM me if you wish.
Oh god here goes, i havent, i have heard of reducing pins but thought they were a myth, i done internet searches but couldnt find any!has no one heard of ISCOs.?
There are several links to them, throughout the forum, Mate.Oh god here goes, i havent, i have heard of reducing pins but thought they were a myth, i done internet searches but couldnt find any!
Forgive me lost here the link is for henley blocks, mainly used for splitting tails, i thought we were trying to get a large conductor in a small hole, or have i left myself wide open again?http://www.tlc-direct.co.uk/Products/RDCB3.htmlthere we go.
you can get them in DP versions too, but I prefer the SP versions myself,
BTW, Im quite proud of myself being able to find a link to something.
Patch PM'd us all saying you asked him to find the link for you!!!http://www.tlc-direct.co.uk/Products/RDCB3.htmlthere we go.
Can we fix it??Is it in the kichen....What Am I going to do?
Patch is a tell tale,,,,,,,, bad day explodePatch PM'd us all saying you asked him to find the link for you!!! :^O:^O:^O:^O
:slap :slap:slap:slap:slap:slap
Patch is a tell tale,,,,,,,, bad day explode yes it is as you call henley block, why not just take all the MEBs and the EC out of the CU and put them into the ISCO.?
he has a 16 mm in already just need to cut it in half and stick and earth block in and put bonding in there also. if possibleWhy not you sayCos you still need a 16mm from the block to the DB and the terminal hole is still too small
no you dont, unless there is a reg that I obviously dont know,Why not you sayCos you still need a 16mm from the block to the DB and the terminal hole is still too small
or another way of doing it which is probably even better,he has a 16 mm in already just need to cut it in half and stick and earth block in and put bonding in there also. if possibleanother thought would a crimped on lug work then screw through it on the the earth bar on the cu?
ive had to do this a few times. mostly on older boards that wont take a 10/16mmanother thought would a crimped on lug work then screw through it on the the earth bar on the cu?
no you dont, unless there is a reg that I obviously dont know,you need a 16mm earthing conductor to the MET, which you have now moved outside the CU to your henley/ISCO.
you need to join the earth terminal in the DB to the MET. Do you think it acceptable to join with 1.0mm? No? Then what size and why?
I think it should still be 16mm to take all the power from a dead short at the DB but maybe it should just be the largest earth conductor size present on the earth terminal. I dont know for sure what do you think? :C
