Donnie76
Hi
Not done a lot off testing but I'm a bit confused on this result. 2.5 ring in plastic truncking and the cable is fp200. Tested both lines ...0.14 ohms, same for neutral but the cpcs come back as 0.00 ohms. Checked connections all seem okay. Its a fluke tester and its about a 20 metre run.Is this a good reading or not for a ring cpc? I thought it had to be higher than the other readings. Thanks in advance.
