Kewtech Socket Tester Adapator
padawan
Nov 9, 2015
22
HI guys, I'm thinking about buying one of these for doing R1 and R2 tests, one of these
http://www.tester.co.uk/kewtech-kewcheck-r2-socket-tester?gclid=CLHQ-JS78MkCFUESGwodSsEC5w
my insulation-continuity tester is the Robin 3075DL using  SL20 test leads like these
 http://www.ebay.co.uk/itm/Robin-SL20-Unfused-Test-Leads-NEW-/151865396941
Does anyone know if the SL20 test leads are compatible with the 4mm jack plugs used by the socket tester adaptor? Or do i need to get new leads to use with the adaptor, if so what leads would i need?
Btw do any of you use the Kewtech adaptor and recommend it?
