Just to stick my spoke in the wheels of kitchendom!!!!!
Personally when I am doing kitchen work..
and I do occasionally do complete kitchen fits as well as just electrics.. ]
I put Non-Switched fused spur behind the appliance location..
and run that back to a suitably accessible double pole switch, fixed somewhere to the building.
Although the regs do not say you cant fit sockets on kitchen furniture..
The IEE Electricians guide to the buildings regulations does not recommend the above method of fixture..
And I have come across many a kitchen installation where, to try and work out where an appliance can be isolated from is like lookin for a needle in a haystack! :|
stuck at the back of cupboards.. behind the cornflakes... wires cut too short.
Or
Step ladder jobs into high cupboards above eye-level ovens!
and
You have to be a ruddy contortionist to be able to get to access & inspect the socket! :_|
The above mentioned publication..
ISBN 0 86341 463 X
Page 56.
Paragraph 5.2.2 Location of accessories in kitchensGeneral guidance can be provided as follows:
(i) Wiring accessories (e.g. socket outlets, switches) should be mounted on the building fabric and not kitchen furniture.
(v) Socket outlets supplying washing machines and dishwashers etc, should be positioned so that water that may drip from plumbing or equipment is unlikely to affect the socket outlet or plug.
(vii) Socket outlets supplying appliances pushed under work-surface e.g. dishwashers, tumble dryers and fridges should be accessible when the appliance is pulled out.
(viii) Appliances built into kitchen furniture (integrated appliances) should be connected to a socket outlet or fused connection unit that is readily accessible when the appliance is in place and in normal use or supplied from a socket outlet or other connecting device controlled by a readily accessible double pole switch or switched fused connection unit.
Obviously there are some of the bullet points omitted there.. (to do with lighting & other bits)
But the ones relevant to socket & appliance I have included.
Again ... This is NOT the regs... but just Guidance for GOOD practice!
and as always we each "pays your money & takes your pick"?
Personally I endeavourer to follow the above guideline with any kitchen work I am doing or quoting for!
