paul b b Well-known member Joined May 26, 2009 Messages 1,751 Reaction score 1 Location stuck between a firm pair of t*** Aug 23, 2010 #1 hello chaps, when putting boxes in lath and plaster what do you do if you hit a stud on one side? thanks
L loonytoon Senior Member Joined Jul 12, 2009 Messages 183 Reaction score 2 Location Dorset Aug 23, 2010 #2 Get a hammer and chissel and cut it out. Sometimes find its easier to drill most of it out with a 20mm spade bit first.
Andy™ ©Resident Geordie™ Supporting Member Joined Jan 1, 2009 Messages 30,747 Reaction score 1,472 Location S. Tyneside Aug 23, 2010 #3 chop off the lug part, so its just a flat side against wood. then put a screw through the side into the wood. same applies to plasterboard walls.
Riggy Senior Member Joined Feb 29, 2008 Messages 1,019 Reaction score 0 Location The Eden Valley, Cumbria. Aug 23, 2010 #4 [quote name='Andy
paul b b Well-known member Joined May 26, 2009 Messages 1,751 Reaction score 1 Location stuck between a firm pair of t*** Aug 23, 2010 #5 ah andy, is that a drylining box? good idea! thanks
Andy™ ©Resident Geordie™ Supporting Member Joined Jan 1, 2009 Messages 30,747 Reaction score 1,472 Location S. Tyneside Aug 23, 2010 #6 ah andy, is that a drylining box? good idea! thanks Click to expand... yes
davetheglitz Electrician Joined Mar 18, 2008 Messages 822 Reaction score 1 Location Saltash, Cornwall Aug 26, 2010 #7 Often good to use 47mm dry liners to allow for extra depth of lath and plaster. Sometimes lucky and the hit the stud and 25mm back box will screw in. Sometimes excavate with multisaw. Sometimes make a frame to take a metal back box and screw in to surrounding wall Either way I never know how to deal with it in advance as there are so many variables. hate the stuff!
