No; from the datasheet it appears that is a 500mA constant current driver.
I did try to set out the various parameters and degrees of freedom that must be met in my previous post.
Perhaps a local electronics repair centre could repair the existing driver or build/modify a replacement unit for you.
I see.. yeah i did wonder about that ampage being a bit higher than the orignal.
Is it possible i could just introduce a resistor into the circuit to drop down this rating to 220mA~ respectively?
If so, any chance you could provide some examples that would be sufficient? Thanks!
