LED strip wiring confusion
phill3880
Jan 17, 2025
Stoke-On-Trent
Hi, i have purchased some LED strip lights designed to sit within the gaps of a wall slat panel. They have arrived though with with just 3 bare wires, red, white and yellow, waiting to be connected up. What do i need to purchase in order to end up with these being pluggable into your standard 3 pin uk wall socket?
Thanks in advance
    2 MB
They will need some sort of LED driver to convert the 230v AC wall socket voltage down to whatever voltage the LED strips require..
Guessing either 12v or 24v?
Do you have any technical spec info for the LED strips?
Most UK compliant electrical gear should come with appropriate installation connection instructions included with them
Is there any writing on the back of the LED strips giving info like voltage, power, make model number??
