Hi guys,
First time poster, I'll get straight to the point.
What I have: Single normal on/off switch and I use an energy saver light bulb which has a Bayonet (B22) fitting. Additionally, I also have one of those 'pull cord' switches in the room- this switch, however, will only work if the main switch is ON.
IT WONT LET ME POST LINKS SO INFO IS IN BRACKETS.
What I want: A dimmer switch with a dimmable light bulb. I have found a suitable dimmer switch (AMAZON- Varlight LED dimmer switch (£14.95)) and lightbulb (AMAZON - Phillips Master LED 12 watt (£26.64)).
Questions/Help
1- Will the 'pull cord' switch get in the way of how the dimmer functions?
2a- The dimmer switch and bulb shown above are very pricey, are there cheaper alternatives?
2b- Cheaper ones I've found mention no minimum wattage for bulbs.
2c- If someone could link me to a suitable dimmer and bulb would be much appreciated.
3a- Are there any 2-way or 4-way splitters available for Bayonet bulb fittings? I've only come across splitters for screw type fittings (E27).
3b- If no, AND IF I still want to use multiple bulbs (to meet the minimum wattage requirement), is the only way to do this to buy a B22 to E27 converter?
Any other help is also hugely appreciated!
Shish
Questions/Help
Shish
