I can't go into too much detail, but suffice to say section 710 is not quite applicable, bearing in mind the recent changes.
I have a patient environment supplied by an SWA sub main from the origin, which will be suitably fused.
Terminology carefully selected.
The sub main is RCD protected within the dwelling.
The patient environment is a "portacabin" type building in the garden of the dwelling.
In the event of the RCD tripping, and it being dark, the "patient" would have to work by emergency light for a little while, go out into the weather, back into the dwelling to reset the RCD.
Then return to the patient environment.
I want to persuade my client to change this to having an RCD in the DB in the "portacabin", however I NEED to put a reg no against it, I can't find one.
I'm not looking for work for works sake, but I believe that it should be done for "patient" convenience.
I don't think I can use 134.1.1, or 510.3, so, struggling to think of one.
I don't like it, but unless I can give a reg no. I can't really code it, or get them to do it, if I can then I can get them to let me sort it when I sort the other issues with the sub mains.
The existing RCD must be changed for other reasons, I just need the reg no to give me the reasons to move it into the CU & replace the CU, replacing the existing RCD with a main switch or terminal block.
To replace or re-work the sub main is a non starter & the RCD is part way down the sub main, so it will not reach its origin without a JB of some sort.
Whilst I know it is not dangerous, I would like to give it a C3, but can't at the moment find a valid reason!
Any suggestions as to suitable reg. no.'s please?
