A better way to die than on the toilet ............................Installing a shower isolator in a very tight cupboard. Am thinking to myself "I am not phoning those pesky Scottish Power ****ers to isolate the mains and I can get them into the main switch terminals live without cutting the seal" (which I did)... (so there!)However... wrestling with the double insulated cables going into new isolator to try to fit them underneath the existing db lid, I managed to pull both L and N from the terminals inside the new isolator. They don't, of course, just sit harmlessly in fresh air, they short straight across each other with a nice flash and not too loud a bang.
And there you have it... one rather perturbed homeowner (who of course was standing right there) and one rather embarrassed electrician!
You can all sleep easier tonight knowing it happened to someone else!!
good reason to tape the end...Installing a shower isolator in a very tight cupboard. Am thinking to myself "I am not phoning those pesky Scottish Power ****ers to isolate the mains and I can get them into the main switch terminals live without cutting the seal" (which I did)... (so there!)However... wrestling with the double insulated cables going into new isolator to try to fit them underneath the existing db lid, I managed to pull both L and N from the terminals inside the new isolator. They don't, of course, just sit harmlessly in fresh air, they short straight across each other with a nice flash and not too loud a bang.
Blew the fuse, don't work with live mains too often but had a look at the main switch terminals and the space in the board and I knew I could get the cables in. Wasn't anticipating pulling them out at the other end when I was trying to get the cover back on though.As far as reinstating the fuse goes, I would definately call the supplier. Don't know about anywhere else but in Scotland they cannot charge you to replace the fuse specifically because it is sealed (meaning your client cannot get a competitive quote to replace it.) I was informed of this by a Scottish Power emergency call out electrician just before Christmas when I managed to blow a main fuse at a property I was working on... don't ask!!
but that would cost moreYup, all of the above... but should we need to? Better quality terminal screws, tougher casings??
I was going to say..yes i was going post the same specs :^O
yep inclined to say yes to care when tightening!Blew the fuse, don't work with live mains too often but had a look at the main switch terminals and the space in the board and I knew I could get the cables in. Wasn't anticipating pulling them out at the other end when I was trying to get the cover back on though.Interestingly, I'm sure we all give our cables a wee waggle (oo,err missus) then get a wee extra pinch on them but with newer cb's and main switches you can only get so much before the casing starts to split.
Not making excuses, shouldn't be working live but you definately can't get terminations as tight in these boxes now before the head of the terminal screw busts or the casing starts to warp...
ADMIN's got the sheep worried now he's said he's Welsh:^O:^O:^O:^OI'm a Welshman.......Who mentoned sheep?![]()
