creggors
- Joined
- Apr 1, 2012
- Messages
- 5
- Reaction score
- 0
Hi lads, im wondering if someone could clarify a question I have regarding doing a manual fault loop impedance calc for the circuit shown below (t-n-c-s). As you can see the fault is taking two different paths back to the utility transformer, im trying to determine which path I should base my calculation on,in other words will I have to take the resistance on the main neutral conductor(R3)into account. Should I be assume that the neutral line will have more resistance therefore my fauly loop impedance should be taken from that? I know this is only my first post,but im doing a project and just found this forum.any help will be much appreciated,thanks
