johninlondon1
- Joined
- Feb 4, 2011
- Messages
- 380
- Reaction score
- 0
Had a plastering job to start and electrics looked wrong. Told the owner to get an electrician as I wasn't competent as yet. The Portugese non-electrician has used 1mm t&e cable to connect the sockets (3 rooms + kitchen, 3 circuits 1 for smoke detector, 1 for ring final circuit and one for lights) and wired 2 rooms off one socket creating an additional 5 spurs with double sockets on it. Then he has taken a spur from one of the spurs and made a radial circuit with 2 double sockets in the next room. The circuit was a ring feeding the small kitchen and the 3 rooms and he has changed it all to virtual radial. All the cables to the lights are all wrong and 3 of the 4 rooms lights don't work. Looks like all the plasterboards will have to be removed and flooring taken up. The owner is not happy and some Portugese chef is gonna have a lot of explaining to do. The rooms do not have radiators so it is envivaged that each room will have electric heaters in them. I told the owner that as soon as you plug in a heater and the kettle there is a risk the wiring will fail and possible fire and maybe shock potential. On lighting circuit he used the live conductor as earth and used old red and black cables for the complete circuit, junctions everywhere and no connectors just insulating tape wrapped around. Also the smoke detector was wired with live conductor to earth and earth to live. No green/yellow sheathing at sockets. The list goes on and on. The house is 4 storeys with owner living in basement and 1st floor with 2 x 80+ year old disabled/dementia parents. Top 2 floors are for renting to tenants. People like this should be prosecuted. Apparantly he does a lot of electrical work, so I reckon he should be made to account for his work and each job he has done should be meticulously tested as he is an obvious danger to persons and property.
