- Mar 28, 2008
- 14,487
- 1,155
:^O :^O:OOld Fashioned it is then !!!!
you are a cruel man Theory!!!
good job we are still in a festive mood!!
:xGuiness Drink
well I am happy...
just had the postman bring me a cheque for
Some may call you old fashioned....i would still fix it, call me old fashioned.
Concur with that point m8...i guess so .. i get a little peeved though no one has any money any more.every one has sky and big tv`s and a new car on the drive but when it comes to maintenance round the home they try to scrimp and save, seems a crazy world we live in.
Welcome to the forum MalcyB!HiI have a similar problem. I have just changed my CU, (ready for Elecsa assesment). On doing the tests I found one of the rings (mainly kitchen skts) without continuity on L&N, CPC is fine, I have tracked down which leg it is. But won't be able to repair it till after the assesment, so I am putting in a 20Amp MCB as a temporary measure untill I can.
Lesson learnt, make sure to do a full PIR before a change.
Well at least ring continuity... before passing the point of no return (pun intended)Lesson learnt, make sure to do a full PIR before a change.
Would you buy the Missus a new car and then dismantle and remove the airbags to avoid the inconvenience and expense of them going off? No, chances are you'd be buying with one eye on safety and looking for a car with good EuroNCAP rating.So, given that RCDs are the airbags of the electrical system, why are you all looking for reasons NOT to fit them? Surely the personal safety they bring is beyond the cost? An off board RCD in a 2 module enclosure is about
Or you could fit 30 of these - 1 to every single applianceSorry PC but where do you stop ? What about the other ring in the house and the shower and the lights. Replace CU ? IMO you have gone to attend to a fault on a 15th or 16th edition installation not to upgrade the installation to the 17th. I take your point and obviously it must be left in a safe condition but we are not the Electric Police. :| Deke
Just at the back of Steptoes yard where some poor sod has to scoop up all of Hercules manure to put on Admins roses!!!Or you could fit 30 of these - 1 to every single appliance13 Amp RCD Plug
where does the madness end?
Specs i cant believe that you can do stuff like that :^O :^OJust at the back of Steptoes yard where some poor sod has to scoop up all of Hercules manure to put on Admins Bed!!! ; )BlushingApplaud Smiley] :|BlushingGuiness DrinkGuiness DrinkGuiness Drink
Square D which type as if it is the older type the RCBO's can cost nearlySquare D. He has lived there 5 years, board there when moved in. Never seen square D before myself.
