dont forget the fung shooey effects as well, if you point all the screwheads to the door all the power will go outside!
I have (embarrassingly) also lined up the heads under those, matter of habit.Why not push the boat out, and get the posh accessory's with the little white inserts that cover the screwheads? Job done!Although they are a pain to get back out again!
My method....leather the front/side of the switch with the rubber/plastic handle of a driver. plastic cover just drops out [well it does for me]... :coatWhy not push the boat out, and get the posh accessory's with the little white inserts that cover the screwheads? Job done!Although they are a pain to get back out again!
Maybe that's not so daft... I once managed to convince a house mate that there were enough 'free electrons' in the air to conduct electricity, so if you left a socket turned on with nothing plugged in, it still ending up costing you money as the power leaked out... (mind you, we also convinced her that the word gullible had been removed from the next issue of the Oxford English!)dont forget the fung shooey effects as well, if you point all the screwheads to the door all the power will go outside!
