ian932
Did anyone see that cowboy builders on channel 5 on Thursday, Melinda shows the 1st fix cables running horizontally to a socket at the same level as the socket and they were clipped direct to the ash block wall. She then said this was dangerous and incorrectly installed as you may accidentally nail through them when fitting plasterboard to the block.
What she should have said was that the idiot builder should be dot and dabbing the plasterboard to the block and not screwing them on !!!
Now every client that you have worked for that saw this will be calling you to say 'you know those cables you fitted horizontally are illegally installed'
Channel 5 please sort your facts out X(
