- Feb 27, 2008
- 11,015
- 0
Finally he has gone to bed.
Just makes it hard when joe public want to put on a new decorative switch...thats now a fairly common way of wiring lights - loop in at switch instead of light fitting. means you only got 1 cable at light for when joe public wants to change it
Hello welcome to the forum...Hi allI`m new here - first post.
I have got myself my first house' date=' and I have paid a sparky to re-wire it, but he missed a cable out on the 2way upstairs/downstairs lighting ( as well as the front lounge & back dinning rooms. )
[/quote']
erm....
Paid a sparky to re-wire it.. thus assume;
1/ You have an Electrical Installation Certificate for the work done.
2/ It has been notified to the LABC and you have a compliance certificate (received or due)
Question: Did the spark self certify his work and is he a member of one of the approved part P schemes?
If yes to the above then
IMHO you tell the sparky to come back and put right his c0ck-up at his own expense then???
Or...
follow the complaints procedure through his scheme provider to put it right?
Or...
did you not have a written quote agreement stipulating the work to be done??
for ANY major works.. a reputable spark should provide some written agreement
of schedule of work to do & costs?
Or are we talking a back-hander no certificates do it quick and cheep job?
the thing is' date=' when we realised that more cables were needed - it was too late, all walls were plastered and papered, ready for paint. - Could not go back as a tight schedule to move in on time.
[/quote']
pull out the two supply loop in and out cables..
that will leave enough room for a 3core & earth (smaller than 2 x T&E)!
No you haven't!I have covered the earth wire with a PVC sheaf and coated that in red insulating tape.
you may have covered the exposed ends of the wire
but NOT the whole uninsulated length down the run of the cable.
it is predominantly an UNINSULATED conductor.
as one of the other guys said
the bare wire is sheathed against mechanical damaged..
BUT NOT insulted to carry 230v and whatever current is passing through the light!
ALSO RED insulating tape?????
why are you using an incorrect colour to identify what you perceive to be a live conductor?
IF it was permissible you would be using BROWN not RED!
or isn't the new wiring done to the correct blue/brown/black/grey colour codes?
So' date=' question is, is this `safe` to continue using? would it pass tests?
Simon[/quote']
No its not.
and no it wouldn't!
obviously it would appear to work...
but them my car appears to work with no water in the washer bottle..
and an air bubble in the hydraulic brake fluid...
that is until my windscreen gets cacked up an I want to stop quickly!!!!![]()
I assume from your picture that the "two pairs of supply in & supply out"ok heres the pic :
NO!I worked out that I will need 5 cables between,a live feed, 2 switching commons, and 2 more strappers
in a single system, I need a 3core, so yes I know that suggests that 3 wires needed for 2 systems, but cant the live feed be used as a strapper on both switching circuits? ( ran a simulation of that in a PCB design program and that worked? )
so I only need 5 ?
hence a 2c&e extra?
please confirm
The Sparky worked for a company, ( I dont want to name ) Thos he did this off his own back at the weekends. He can`t certificate this himself, his qualification test is later this year. The company he worked for were asked to do the job, but after 3 weeks and several phonecalls, they failed to give a quote for the job. the sparky who did the job worked also on my dad`s house on bigger job than mine, and that worked out fine.Hello welcome to the forum...just looking through this thread and there are a lot of serious issues that do concern me.
I will try to be as clear as I can..
and hope you take them in the context they are ment...
here goes..
Quote:
I have got myself my first house, and I have paid a sparky to re-wire it, but he missed a cable out on the 2way upstairs/downstairs lighting ( as well as the front lounge & back dinning rooms. )
erm....
Or...
Or...
There were channels cut out of the wall, the cables layed in and then plastered over. if I were to pull a cable out it would damaged the walls.I mentioned above that I may have the time to out out the wall again and put a new cable in, but I realised this morning that would be inpossible, as the cable (upstairs) runs thro a stud partition, and the room each side of that is now complete, so I cant disturb that wall. There is no other way of getting another cable between the switches. ( what are these remote ones guys are on about - never knew about them ? )Quote:
the thing is, when we realised that more cables were needed - it was too late, all walls were plastered and papered, ready for paint. - Could not go back as a tight schedule to move in on time.
Red tape I know is the incorrect colour - just what I had to hand at the time, either that or yellow. All wiring in the house is new, so new colours throughoutQuote:
No you haven't!
I`m quite sure too that it would not pass. We plan to get that done in the very near future, - just need to put a ringmain in the garage, and wire up external security lights.Quote:
So, question is, is this `safe` to continue using? would it pass tests?
Simon
No its not.
and no it wouldn't!
yeah its 2 circuits, I realise about them both feeding the lights & cables,I assume from your picture that the "two pairs of supply in & supply out"at the upstairs & downstairs switches are on two different circuits?
e.g. FUSES or MCBs at your fuse box...
because if so.. it looks like your two circuits are not isolated from each other by that drawing,
In which case? is it a split load 17th edition compliant CU
OR do you actually only have one lighting circuit..
but you just like looping loads of extra wires in???
and your three core & E is carrying 230v from TWO DIFFERENT supplies!! :_| :_| :_|
That most definitely needs sorting out !!
as it does look very DIY amateurish!![]()
Hi SimonOn a final note, I know the only 2 options I have is to replace the cablesor to add a remote
I will look into adding a remote, tho I never seen these before.
Simon.
i hope you dont plan to sell the house.So unfortuantly, I have no `official` paperwork to say this was done.
Dare I ask about an RCD on this circuit, or will I get an answer I don't likeThere were channels cut out of the wall, the cables layed in and then plastered over.
probably the same side to stop it tripping....Dare I ask about an RCD on this circuit, or will I get an answer I don't like![]()
