tom1
Distinguished Member
- Aug 7, 2009
- 2,330
- 0
got a 2003 mondeo 2l tdci,
its been fine for the last 3 years. got it serviced, they said it needed tracking, tyre resealing as it keeps slowly going down and a new battery as it is on the verge of failer.
got the tracking done and tyre done,
got the battery tested elsewere and it tested fine.
the tyre was flat in 2 weeks, took it back and they replaced the valve.
few weeks later mot.
failed on corroded rear break pipe, and noted the exhaust hanngers were week. took it to a different garage than the one who serviced it, they said, the whole break pipe needed doing and when the checked the exhaust and the front part was nearly worn through so they replaced the break pipe and exhaust. this was new years eve. new years day drove 125 miles on motor way. day after on way back abs light comes on, and i lost the abs so cant take car for mot retest.
took it to ford diognostic kit showed no faults they said its prob an airlock in the pump take it back to who did your breaks get them to bleed it.
girl friend picked up car and breaks would not work so refused to drive it. the garage who did break pipes picked it up and said apart from no abs breaks are fine. the abs wire on rear has come lose fell on tyre and worn through. so why did ford diognostics not pick up on it, they said they will bleed it for free and replace the abs sensor for
